Joe, the duct tape trick is something I learned with the original scissors type TRUE mount. As you know, the original mount had a bad problem holding the heatsink from rotating on top of the processor. I figured that it was due to the bracket having so little contact area between it and the top of the heatsink base. I put the tape originally to give a stickier than metal to metal contact patch between the top of the heatsink base and the scissors bracket and let the bracket "dig in", so to speak. And it works well in that regard. But I also noticed that I started getting lower load and idle temps after doing this too. When you add a strip of the duct tape across the top of the heatsink base (the part that the clamping bracket contacts on the base), the layer of tape also acts to thicken the base that the bracket has to clamp against, giving more clamping pressure. How much more I really can't tell you since I don't have the sophisticated equipment necessary to check the clamping pressure but it does increase it somewhat. And just to double check that the better temps weren't due solely to the heatsink not rotating on top of the processor when clamped, I carefully had mounted the TRUE without having any heatsink movement and ran a stress test, then did the duct tape trick and retested and saw a decrease in temps using the duct tape.
I participated in the OCF IC7 tests, where can I get this new Perihelion TIM?
