Initial Test Results: MX-2, IC-D, Perihelion
Test Setup
Hardware in Signature
General Info(Constants)
Vcore: BIOS-1.2565v, IdleCPUZ-1.2480v, LoadCPUZ-1.2480v
Fan Voltage: 10v(9.7v actual), RPM: ~2200, CFM: ~85
Methodology
- CPU is loaded with Prime95 Large FFTs for 30 minutes to allow loop to stablize.
- CPU core temperatures recorded with Real Temp 3.36.
- Ambient air temperature recorded three times. Once b4, once during and once after the stress test.
- Ambient temperatures taken as the average of three thermal sensors, 1" above the hub of each of the three rad air intakes.
- Water temperature input for delta measurement taken with inline teperature sensor 1" after rad outlet.
- System allowed to cool down until stabilized after each test to record idle water and core temperatures.
Results
MX-2: Pre Applied-5mm Dot Method
Ambient Air Temp Shot
Spread
Idle + Load
Required Data
Compound: MX-2
Ambient Temp: 25.8C
Idle Temp: 41,35,38,36
Load Temp: 63,59,60,57
Additional Data
Avg of three ambient air temp sensors: B4: 25.85 DegC, During: 25.80 DegC, After: 25.40 DegC.
Water Temperature Idle: 26.50 DegC.
Delta idle 1.10 DegC.
Water Temperature Load: 28.90 DegC.
Delta load 3.10 DegC.
Avg Core temperature idle: 37.50 DegC
Avg Core temperature load: 59.75 DegC
IC-D
Application
Spread
Idle + Load
Required Data
Compound: IC-D
Ambient Temp: 25.4C
Idle Temp: 39,35,38,35
Load Temp:63,59,60,57
Additional Data
Avg of three ambient air temp sensors: B4: 25.30 DegC, During: 25.40 DegC, After: 25.35 DegC.
Water Temperature Idle: 26.30 DegC.
Delta idle 0.95 DegC.
Water Temperature Load: 28.80 DegC.
Delta load 3.40 DegC.
Avg Core temperature idle: 36.75 DegC
Perihelion
Ambient Temp Shot
Application
Spread
Idle + Load
Required Data
Compound: Perihelion
Ambient Temp: 25.2C
Idle Temp:40,35,38,36
Load Temp:64,60,61,58
Additional Data
Avg of three ambient air temp sensors: B4: 24.90 DegC, During: 25.20 DegC, After: 24.95 DegC.
Water Temperature Idle: 26.20 DegC.
Delta idle 1.30 DegC.
Water Temperature Load: 28.60 DegC.
Avg Core temperature idle: 37.25 DegC
Avg Core temperature load: 60.75 DegC
Comments and Observations
- Yes, my core temperature results for the MX-2 and IC-D are exactly the same down to the core.
Didn't notice till I started compiling and it's just a fluke. If you look closely, the max and min temperatures differ between runs.
- Ambient Room temperature stayed between 23 and 23.5degC throughout the entire test series. Ambient air temperature at the rad intakes was noticeably,
but not significantly warmer at between 25.2 and 25.8degC.
- I tried 4 applications of the perihelion and finally got a decent spread(albeit with what looks to be WAY too much TIM). Twice with a
5mm dot method,
and once with a 6 or 7mm dot(as in my application link). And then once by spreading the TIM with my finger out to the edges of the IHS which also
produced better results than with the 5mm method. I am confident that the insufficient spread with the
5mm method was not due to uneven mounting, as I took great care each time.
