- Nov 6, 2001
residentevil2 said:guess were getting outa subject here
<------- soppose to help me
ok im on stock speeds 1.72vcore wont work.
i cleaned the whole cpu cleaned the pits out all of them with a little tiny thumb tab pin. then i cleaned the cpu with a tooth brush and a little water. then used and erraser to clean the burn marks from the laser cutting the bridges.
Turnd the computer on put on 1.80vcore went into windows xp. WOW it was a little slow tho but 5 min later it locked up and i couldnt get in cept by using 1.70vcore or less. so somethings wrong with the cpu i just dont know what.
How could cleaning the cpu like that alow me to get in win xp for while
too true, sorry, i will remove my post once the flame goes away.
for your problem though, how do you *KNOW* its the cpu? have you tested a different cpu in there? that might be a good idea before you work at getting a replacement for that one.
