I may be walking on a limb farr ouuut there, but let's see
residentevil2 said:
ok this is what i have hooked up now.
>9700 pro radeon :
doesn't use 12V
>maxtor ata 133 7200 40 gb drive
WWW. mwaxtor.com gives max 434 mA for 12V for seek operation for Diamonf max plus 8 model
>Cdrom, DvD,
Amd says .8 A for each
>Floppy
>2x256pc 2700
>2 small fans not sure how big but the size of a north bridge on the mobo.
typical fans draw .24 A
>The psu has 2 fans plugged up
should not count
after factoring in 7.5 we are still below 12A
>Now my xp 2000+ i got to 2ghz using 2.14v
XP200+ is 1667Mhz, 1.6V, 38.3 A
I guess XP2000+ at 2000Mhz at 2.14V, 41.3 A (because of my assumption of 1A per 100Mhz) would draw
2.14 * 41.3 / 12 * 1.25 = 9.2 A
So if you manage to run stable your 2000+ at 2000MHZ with 2.14V, it is not the max amperage on the 12V line of your PS which is preventing you from pushing your 2400+ further.
So no need to go and buy another PS, it won't help.
You may nonetheless plug you CPU into another MB with another PS to double check (and be ready to cry)
> My 2400+ i can only get 2150mhz stable but using windows 98 since it actually boots up but has errors i can get 2350 mhz on 2v.
But like it is it isnt stable on 1.70v or more
Again, pushing more voltage than planned into a CPU helps overclocking because it makes the signal stronger, so easier to detect over the noise. H
Your own experience with one of those early CPU just tells you that however strong the voltage you throw, there is enough electrical noise because of the speed to cause random error, which crash your system.
Please remember the Pentium III 1.3Ghz fiasco, (Yes, that was one of the last interesting piece from THG). A CPU which is pushed beyond the process capability will fail if excercised in a certain fashion.
I hoped to have help you understand the complex issues of which I have only a partial understanding myself.
