- Feb 14, 2003
I have an asus a7a266 with a pally 2100+. I'm starting to get instability problems yet again on it, which I think is because of temperature.
I have a very good all copper heatsink with a high power fan. I have a vantec tornado blowing cool air from outside the case into the cpu fan which blows the air down onto the heat sink. I have a blow hole custom modded into the top with a vantec tornado exhausting hot air. I have a ys tech 50 cfm fan blowing cool air into the bottom of the case. I'm using premium silver thermal goop.
My cpu is still running at 58-59C with load (folding) and it's starting to crash again. I know it's partly the motherboard, the a7a266 motherboards kind of suck for heat purposes.
I have a sunbeam fan controller. When I lower the fan speed by 50%, there is no difference in temperature. Essentially, I think the air flow is good enough that I'm getting maximum cooling with the ambient temperature being what it is. (The ambient temp is pretty high in here, and is only likely to get worse over the summer).
So, if I can't change the ambient temp, and increasing air flow through the case isn't going to help any more, what else can I do to stabilize this system? It's really starting to crash a lot.
If I can't figure it out I may have to cut down on the folding and cap the cpu at 50% or something.
If I put a thoroughbred b 2600+ 266 in there instead, will it likely run cooler than the pally?
