I Doubt a dremel would help me with my 6002...
My 6002 has a step in it.....
It's been a long night, but here were are at 3.4GHz. Took forever to get the WC loop installed as there always seem to be unforseen problems.
Anyway, I jumped straight to 3.4GHz with the Vcore on auto.
Tomorrow I'll see how far I can push this chip.
Room temp is 72F/22C
Yea, I ended up not having to do jack- just mount and go.Nice!
My 6002 does not have the step (ordered for a P4 system that is no longer here).
However the DFI socket is low enough profile that even my Nekid Mobile Clawhammer has no issues.
I have however found it's much easier to wrap some 80 grit sandpaper around a flat ended pop sickle stick and sand the embossed lettering off of the cambox to make it fit, rather than to try hand-machining the block...all you need is enough clearance to slip a piece of printer paper between them.
