Ok, So I disassembled my EKWB waterblock for one of my EVGA FTW3 1080 Ti's and I , for the life of me, cannot get the gasket back in. It appears to not have held its shape, and it is just to big! I did my other waterblock and it went back together just fine without any problems what so ever, but the gasket also was in the shape of the block once removed. For some reason this waterblocks gasket, once separated from the plexi, kinda popped out into a circle shape. It did not hold its shape like the other one. I have been fighting with this thing for 3 hours now, and I cannot get it even close to fitting!!!!! SOME ONE PLEASE HELP ME!!!
Edit: Hey GTX, it seems that on this particular block, the gasket was used from a different block and installed by machine. I just do not see any other way to get it in. It seems to be about a half to three quarters of an inch to big/long. I have posted in the EKWB Vendors section on a different forum, and also emailed EKWB directly from their website. Murphys Law requires that if there is something to go wrong, that it go wrong with me. I should be a QA tester for some of these companies!!
There was a suggestion on the other forum to use a very tiny bit of sealing gasket maker in a couple strategic spots to aid in keeping the gasket in place while I try to replace the plexi cover, so I will head to the auto parts store today to see what I can find. Anyhoo, I appreciate the suggestion brother!
