- Jan 12, 2012
Christ I don't even think I would be able to boot into windows at the Cpu V, nice board!
Heres a few shots ...
So it's hitting 1.55 Cpu v under load, with the Asrock Ext 9 board?LLC is at 25 [ASRock LLC is backwards to others] and under load it hit 1.55 top
If you want to run that OC then I would suggest getting the voltage down as far as you can and like Manny said not such a big jump, that can cause a crash as well. Once you're stable you can use AMD's own power saving features to keep the clocks and volts down when surfing etc. Just takes a lot of tinkering and time,
What are u guys gettin under load with ur saber boards?
LLC is at 25 [ASRock LLC is backwards to others] ...
Hmm, maybe that's why I'm pushing 1.5v to hit 4.0Ghz. I'm set to 75%. So you think I should try 25% instead? maybe drop my volts down to 1.475v?
EDIT: def gonna flash to new BIOS this week though.
Al modified OCZ cryoz.NICE! Opty, you have a custom loop or on LN2?
