- Dec 19, 2012
What you guys should aim for is something close to your CPU voltage setting in bios. I know the LLC settings don't work like mine do but you need to find a setting that maybe bumps the volts slightly under load. I know when I set my LLC to ultra ant the CPU it will add.025v to my settings. See what I'm laying down?? You have to narrow down the volts needed for your OC . I would stick with the last setting you mentioned Blaylock at 75% you know you get a .0125v increase under load. the wide variance in voltage is too hard to work with.
