- Mar 5, 2004
- 47.6358 N, 117.2528 W
Opty 165
CCBBE 0610DPMW from Monarch.
Ordered 4/24/06.
Ordered 4/24/06.
orion25 said:Well, just got my OCZ 520 back from RMA....
Installed it along with the 165 0610. I am at 2.7 on stock voltage using a 333 Divider which gives me 250 fsb. Temps are 41C using a Thermalright XP-90 (AL Version). I am going to try for 2.9+ on my next run as soon as I get some improtant info backed up.....
My 3700 San Diego was at 2.75 so I consider this a good upgrade!!
jcsurg said:Interesting find with the 608 stepping for peeps with under performing 608.
The core on my 608 was not flat ,high on the center, only about 50% good contact. After lapping the core, My 608 will do 2800 stock voltage @ 43 C on air. A drop about 4-5C in temp after lapping.
Helsyeah said:Just out of curiosity, what did you use to lap the core and how did you go about it? I've heard of people using ceramic and diamond polishing agents, but I would assume that some glass-backed 2000 grit wet-dry sand paper would get the job done too...
good luck as yesterday I got 2 ccbwe 0607upbw chipscatkicker said:Ordered from Monarch today. AMD Opteron 165 Coupon Code: 42806-120339 still good. Will post stepping when it arrives.
