I am going for it! Hi all. Thanks in advance to the wealth of knowledge I have found here I am approx 1 week into an OC learning curve. I just upgraded my rig to a FX-6100 on an Asrock 880GM-LE. Steep but interesting learning curve. I just PASSED a 2h5m PRIME test @ 4.5Ghz, CPUv1.5250 NBv1.1250 A previous 90min PRIME Test @ 4.5Ghz ended with an ERROR: ILLEGAL SUMOUT using CPUv 1.5125 & CPU NB 1.1750v. One of the cores spiked above 70C & shut down the worker. Surprisingly system remained stable. This time temps stayed between 58C - 61C, reaching 65C once for approx 2mins. Plus I'm able to use the system while PRIMING without notice or adversely impacting temperature. I'm so pleased I want to know what else I mean it can do lol
FYI: I like the GUI in OCCT & the ability to set cut off limits on each core as well as the CPU TIN. I prefer the test abort than overheat CPU and/or reboot unexpectedly. Also I'd rather not physically monitor each test configuration likely to push temps to the limit. Once I suspect a configuration will work I test it again in PRIME & let OCCT monitor/record PRIME stress test. I find their temps are within 1 degree if not the same as HWMonitor most of the time and always within 3. Plus OCCT updates more often and records changes less than 1 degree.
PRIME fluctuates CPU between 1.4Ghz - 6.3Ghz using the APM. However my normal use and/or opening every resource intensive program on the system simultaneously/consecutively keeps the CPU nicely around 4.5Ghz. I will still compare it with 4.4Ghz. I reached these levels of stability manipulating only CPU Multiplier, CPUv DRAM and CPU NBv. I hope that the more experienced minds here can advise other settings that would be more effective?
The following are PRIME benchmarks stock & current respectively and results from 2h5m PRIME test. Let me know if you would like any further info omitted.
[Sat Feb 09 19:42:47 2013]
AMD FX(tm)-6100 Six-Core Processor
CPU speed: 3306.32 MHz, 6 cores
CPU features: RDTSC, CMOV, Prefetch, MMX, SSE, SSE2, SSE4
L1 cache size: 16 KB
L2 cache size: 2 MB, L3 cache size: 8 MB
L1 cache line size: 64 bytes
L2 cache line size: 64 bytes
L1 TLBS: 32
L2 TLBS: 1024
Prime95 64-bit version 25.11, RdtscTiming=1
Best time for 768K FFT length: 12.454 ms.
Best time for 896K FFT length: 15.031 ms.
Best time for 1024K FFT length: 16.979 ms.
Best time for 1280K FFT length: 21.479 ms.
Best time for 1536K FFT length: 25.828 ms.
Best time for 1792K FFT length: 31.380 ms.
Best time for 2048K FFT length: 34.975 ms.
Best time for 2560K FFT length: 46.959 ms.
Best time for 3072K FFT length: 57.516 ms.
Best time for 3584K FFT length: 68.530 ms.
Best time for 4096K FFT length: 76.589 ms.
Best time for 5120K FFT length: 99.375 ms.
Best time for 6144K FFT length: 120.810 ms.
Best time for 7168K FFT length: 145.671 ms.
Best time for 8192K FFT length: 161.117 ms.
Timing FFTs using 2 threads.
Best time for 768K FFT length: 9.728 ms.
Best time for 896K FFT length: 11.683 ms.
Best time for 1024K FFT length: 13.502 ms.
Best time for 1280K FFT length: 16.303 ms.
Best time for 1536K FFT length: 19.533 ms.
Best time for 1792K FFT length: 23.559 ms.
Best time for 2048K FFT length: 26.426 ms.
Best time for 2560K FFT length: 34.969 ms.
Best time for 3072K FFT length: 42.501 ms.
Best time for 3584K FFT length: 50.593 ms.
Best time for 4096K FFT length: 57.127 ms.
Best time for 5120K FFT length: 73.964 ms.
Best time for 6144K FFT length: 89.188 ms.
Best time for 7168K FFT length: 108.999 ms.
Best time for 8192K FFT length: 121.247 ms.
Timing FFTs using 3 threads.
Best time for 768K FFT length: 7.642 ms.
Best time for 896K FFT length: 7.891 ms.
Best time for 1024K FFT length: 12.143 ms.
Best time for 1280K FFT length: 10.451 ms.
Best time for 1536K FFT length: 12.561 ms.
Best time for 1792K FFT length: 15.113 ms.
Best time for 2048K FFT length: 17.050 ms.
Best time for 2560K FFT length: 22.505 ms.
Best time for 3072K FFT length: 27.429 ms.
Best time for 3584K FFT length: 32.883 ms.
Best time for 4096K FFT length: 36.969 ms.
Best time for 5120K FFT length: 47.844 ms.
Best time for 6144K FFT length: 57.773 ms.
Best time for 7168K FFT length: 70.165 ms.
Best time for 8192K FFT length: 78.119 ms.
Timing FFTs using 4 threads.
Best time for 768K FFT length: 7.176 ms.
Best time for 896K FFT length: 7.915 ms.
Best time for 1024K FFT length: 11.349 ms.
Best time for 1280K FFT length: 9.078 ms.
Best time for 1536K FFT length: 10.807 ms.
Best time for 1792K FFT length: 12.450 ms.
Best time for 2048K FFT length: 14.112 ms.
Best time for 2560K FFT length: 18.407 ms.
Best time for 3072K FFT length: 22.290 ms.
Best time for 3584K FFT length: 26.809 ms.
Best time for 4096K FFT length: 30.098 ms.
Best time for 5120K FFT length: 38.782 ms.
Best time for 6144K FFT length: 46.929 ms.
Best time for 7168K FFT length: 56.813 ms.
Best time for 8192K FFT length: 63.521 ms.
Timing FFTs using 5 threads.
Best time for 768K FFT length: 6.529 ms.
Best time for 896K FFT length: 7.138 ms.
Best time for 1024K FFT length: 10.583 ms.
Best time for 1280K FFT length: 7.683 ms.
Best time for 1536K FFT length: 8.956 ms.
Best time for 1792K FFT length: 10.331 ms.
Best time for 2048K FFT length: 11.654 ms.
Best time for 2560K FFT length: 14.869 ms.
Best time for 3072K FFT length: 17.630 ms.
Best time for 3584K FFT length: 20.996 ms.
Best time for 4096K FFT length: 23.727 ms.
Best time for 5120K FFT length: 30.479 ms.
Best time for 6144K FFT length: 36.746 ms.
Best time for 7168K FFT length: 44.893 ms.
Best time for 8192K FFT length: 50.140 ms.
Timing FFTs using 6 threads.
Best time for 768K FFT length: 6.443 ms.
Best time for 896K FFT length: 7.034 ms.
Best time for 1024K FFT length: 10.349 ms.
Best time for 1280K FFT length: 7.491 ms.
Best time for 1536K FFT length: 8.735 ms.
Best time for 1792K FFT length: 10.010 ms.
Best time for 2048K FFT length: 11.233 ms.
Best time for 2560K FFT length: 13.911 ms.
Best time for 3072K FFT length: 16.289 ms.
Best time for 3584K FFT length: 19.251 ms.
Best time for 4096K FFT length: 21.735 ms.
Best time for 5120K FFT length: 27.435 ms.
Best time for 6144K FFT length: 32.894 ms.
Best time for 7168K FFT length: 39.732 ms.
Best time for 8192K FFT length: 44.456 ms.
Best time for 58 bit trial factors: 2.937 ms.
Best time for 59 bit trial factors: 2.898 ms.
Best time for 60 bit trial factors: 2.900 ms.
Best time for 61 bit trial factors: 3.038 ms.
Best time for 62 bit trial factors: 3.165 ms.
Best time for 63 bit trial factors: 3.417 ms.
Best time for 64 bit trial factors: 4.120 ms.
Best time for 65 bit trial factors: 5.258 ms.
Best time for 66 bit trial factors: 6.290 ms.
Best time for 67 bit trial factors: 6.255 ms.
CPU speed: 4500.15 MHz, 6 cores
L1 TLBS: 32
L2 TLBS: 1024
Best time for 768K FFT length: 9.553 ms.
Best time for 896K FFT length: 12.089 ms.
Best time for 1024K FFT length: 13.990 ms.
Best time for 1280K FFT length: 17.249 ms.
Best time for 1536K FFT length: 21.212 ms.
Best time for 1792K FFT length: 25.093 ms.
Best time for 2048K FFT length: 32.116 ms.
Best time for 2560K FFT length: 43.119 ms.
Best time for 3072K FFT length: 54.403 ms.
Best time for 3584K FFT length: 59.401 ms.
Best time for 4096K FFT length: 70.583 ms.
Best time for 5120K FFT length: 99.652 ms.
Best time for 6144K FFT length: 113.134 ms.
Best time for 7168K FFT length: 140.049 ms.
Best time for 8192K FFT length: 158.240 ms.
Best time for 768K FFT length: 7.587 ms.
Best time for 896K FFT length: 9.792 ms.
Best time for 1024K FFT length: 11.927 ms.
Best time for 1280K FFT length: 14.721 ms.
Best time for 1536K FFT length: 17.073 ms.
Best time for 1792K FFT length: 19.159 ms.
Best time for 2048K FFT length: 25.039 ms.
Best time for 2560K FFT length: 36.605 ms.
Best time for 3072K FFT length: 44.054 ms.
Best time for 3584K FFT length: 50.084 ms.
Best time for 4096K FFT length: 56.794 ms.
Best time for 5120K FFT length: 80.188 ms.
Best time for 6144K FFT length: 91.603 ms.
Best time for 7168K FFT length: 120.465 ms.
Best time for 8192K FFT length: 134.220 ms.
Best time for 768K FFT length: 6.622 ms.
Best time for 896K FFT length: 6.880 ms.
Best time for 1024K FFT length: 10.696 ms.
Best time for 1280K FFT length: 9.247 ms.
Best time for 1536K FFT length: 11.180 ms.
Best time for 1792K FFT length: 13.250 ms.
Best time for 2048K FFT length: 15.835 ms.
Best time for 2560K FFT length: 20.111 ms.
Best time for 3072K FFT length: 25.606 ms.
Best time for 3584K FFT length: 35.359 ms.
Best time for 4096K FFT length: 37.949 ms.
Best time for 5120K FFT length: 45.700 ms.
Best time for 6144K FFT length: 60.331 ms.
Best time for 7168K FFT length: 75.865 ms.
Best time for 8192K FFT length: 83.519 ms.
Best time for 768K FFT length: 6.881 ms.
Best time for 896K FFT length: 6.946 ms.
Best time for 1024K FFT length: 10.738 ms.
Best time for 1280K FFT length: 8.064 ms.
Best time for 1536K FFT length: 9.661 ms.
Best time for 1792K FFT length: 11.505 ms.
Best time for 2048K FFT length: 13.440 ms.
Best time for 2560K FFT length: 16.921 ms.
Best time for 3072K FFT length: 21.241 ms.
Best time for 3584K FFT length: 27.777 ms.
Best time for 4096K FFT length: 30.009 ms.
Best time for 5120K FFT length: 38.543 ms.
Best time for 6144K FFT length: 50.308 ms.
Best time for 7168K FFT length: 63.711 ms.
Best time for 8192K FFT length: 67.660 ms.
Best time for 768K FFT length: 5.816 ms.
Best time for 896K FFT length: 6.629 ms.
Best time for 1024K FFT length: 9.347 ms.
Best time for 1280K FFT length: 7.103 ms.
Best time for 1536K FFT length: 8.289 ms.
Best time for 1792K FFT length: 9.750 ms.
Best time for 2048K FFT length: 11.348 ms.
Best time for 2560K FFT length: 15.167 ms.
Best time for 3072K FFT length: 22.372 ms.
Best time for 3584K FFT length: 21.538 ms.
Best time for 4096K FFT length: 24.498 ms.
Best time for 5120K FFT length: 34.571 ms.
Best time for 6144K FFT length: 44.448 ms.
Best time for 7168K FFT length: 49.714 ms.
Best time for 8192K FFT length: 63.260 ms.
Best time for 768K FFT length: 6.291 ms.
Best time for 896K FFT length: 6.610 ms.
Best time for 1024K FFT length: 9.501 ms.
Best time for 1280K FFT length: 7.167 ms.
Best time for 1536K FFT length: 8.463 ms.
Best time for 1792K FFT length: 9.895 ms.
Best time for 2048K FFT length: 11.412 ms.
Best time for 2560K FFT length: 14.640 ms.
Best time for 3072K FFT length: 19.200 ms.
Best time for 3584K FFT length: 22.674 ms.
Best time for 4096K FFT length: 24.095 ms.
Best time for 5120K FFT length: 39.857 ms.
Best time for 6144K FFT length: 43.711 ms.
Best time for 7168K FFT length: 51.743 ms.
Best time for 8192K FFT length: 62.111 ms.
Best time for 58 bit trial factors: 2.178 ms.
Best time for 59 bit trial factors: 2.156 ms.
Best time for 60 bit trial factors: 2.157 ms.
Best time for 61 bit trial factors: 2.255 ms.
Best time for 62 bit trial factors: 2.346 ms.
Best time for 63 bit trial factors: 2.542 ms.
Best time for 64 bit trial factors: 3.065 ms.
Best time for 65 bit trial factors: 3.959 ms.
Best time for 66 bit trial factors: 4.811 ms.
Best time for 67 bit trial factors: 5.069 ms.
Do the results include 2 hours of Prime 95 running in Blend mode and the temps not exceeding 70c on cpu and 60c on the package aKa core temps? If it passes that, there is a good chance you could call it stable otherwise it is sitll only a moon shot for giggles. .
