Hi guys, so... I have a ASUS M5A78L-M PLUS/USB3 (MAX 125W PROCESSOR) with a FX 8300 (3.3ghz/95TDP) and googling about overclock with this mobo and processor, I see that's not a good idea because of the vrms and these things, so I bought heatsinks and a cooler to cool the mosfets. The mobo don't have a sensor to monitor the vrm's temperature, but I didn't see a clock drop after the heatsinks on the vrms when I was playing or streesing with the cpuz. The overclock that i'm doing not is 100% stable, but, my focus is the CSGO and with this voltage and clock, the system is stable, but when I try to play dayz or pubg, the pc turn off after a few minutes (I thing that's because I need to increase the voltage on theses games, but I just reduce the clock), buut, like I said, my focus is the csgo and the system is pretty stable with these configs when I play him. The only thing that I need to know is: i'm gonna have a issue using it with 4.4ghz and 1.475 voltage or, if it's stable - no drops of clock, I think that means that the vrms is not overheating, or its better use the normal settings? (OBS: I overclock the bus speed, CPU/NB and the HyperTransport as you can see in the print)
Picture of the overclock settings in AMD OVERDRIVE <3:
