POST #426 out of 10,015 posts. In this LONG thread >>
http://www.overclock.net/t/1023100/official-gigabyte-ga-990fxa-series-owners-thread-club
From Email from Gigabyte:
"GIGABYTE 990 series motherboards strictly follow the AMD AM3+ load line calibration design guide, and so CPU V-core voltage will drop according to loading. Such calibrations are built into the platform to protect the user’s purchase and prevent damage to the PC system"
Edited by Sin0822 - 7/7/11 at 2:42pm
That is why the CPU_LLC is such a freeken mess and MIGHT by pure trial and error on an earlier bios, do a little better.
One of the problems here is that I started following that long thread above before the posts reached 5,000 and now when I go back I found there are 5,000 more added. They go thru the deal with the Rev 3.0 boards and what a freeken disaster that was for many users wishing to overclock with stability. And finally they got to the Rev 4.0 of some of the boards that Gigabyte did finally revise to.
Just about any of the headaches found with the Gigabyte AM3+ motherboards in the 990FX series of boards is HIT-ON within those many posts.
I am not sure you feel flexible enough and maybe skilled enough to do the bios flashing but if you go to the first page of that long thread at OCN there are many tutorials on bios flashing but not links to the older bioses. You might read thru that thread and find one of those guys that saved an older bios like the F6c and get them to mail it to you and then flash it and maybe do some better with that particular bios.
I admit to having not read much of the LAST 1,000 or so posts and that is because no way I cared to listen to Rev 3.0 crying. But you might see that a bios 'later' than the one on your board does work better. The later bioses are easier to find.
By the way posts on PAGE #44 has a perfect description of your voltage issue when you raise it to anything above 1.38Vish or thereabouts. It is not new as a problem.
I have fought with boards like you now own in the past and have found that nothing but sitting at the keyboard and testing this setting and then this setting and back and forth, was the ONLY way to get anywhere. Crappy boards do not have a do A and B and C is the result. They are just not like that. Sorry.
Having the 1,000s of hours tweaking 100s of boards, I could like get that UD7 to pay a little better attention than it is, but it is nearly impossible to do so from a keyboard. Too many variables that must be seen one end and related at the other with clarity.
I used to tweak a buds rig by phone and his cpu was better than mine and he always edged me out in benches most of the time. But the tweaking was done by phone with him making the exact changes as I spoke them. That man is tough. Really tough. The two parties have to be on the exact same wave length. Nothing he saw his end was without value including speed of boot or any oddity.
I say all this to day, you can get some results with your UD7 but you will have back-up and regroup and likely need to look seriously at older bios version or verify that a later bios than you have is in fact a positive move and even more of the same or backing up.
If you are just fed up...go read that long thread. There are many in there that were in your position and moved to other boards. Some lowered their expectations and got a little relief. Of course your time and efforts to do as you will. Better luck man.
RGone...ster.
