- Dec 19, 2012
How about this one and save a few more euro, unless you're going to run multiple cards the 970 chipset is fine http://www.e-shop.gr/gigabyte-ga-970a-ud3p-retail-p-PER.526958
...or will buy from as I understand it. He is not in the Usa. Sabertooth board is nOt listed at that site for AM3+ AMD motherboards.
http://www.skroutz.gr/c/31/motherbo...html?order_dir=asc&price_min=80&price_max=120
Hale yes, if the SaberKitty was shown, it would be my FIRST choice if planning to overclock a snail.
RGone...
RGone...
It's 6+2 and should be good for a mild OC.Oh i see, in that case I would say the Asus M5A97 R2.0 or Gigabyte one that everyone has been recommending. I don't recall if that Asus board is an 8+2 phase or not.
I found it on the site he listed but it's expensive http://www.e-shop.gr/asus-sabertooth-990fx-r20-p-PER.522970
You have a point of course and i respect what you say,but that's all the money i can spend!Also,i don't want to manage some extreme o/c,just normal things!Can understand money. Like I said if REAL in understanding that many boards claim something since they all run the same cpu does not mean in practice they will all work one just like another. IF they all worked alike, then why ask us about what to buy? I mean 'really'! It is because some boards are just better at doing the overclock on FX processors and especially the 6 and 8 core ones.
Anyway,i just oredered the asrock 970 fatal1ty performance.It's a 2014 model and i think it HAS to manage what it promises.Whether it does what it promises will be totally on you since we have no earthly idea how that board works. What its' bios looks like nor what settings are available in bios. So if it gives issues, resolving issues will fall right in your lap. We have no baseline of what if's for that board. Just a real fact. You overclock them all by raising multiplier or FSB and then adding enough voltage to make it stable and keep it cool enough not to burn up. How readily the newer Asrock can do that will be up to you to determine. Just no 100s or more users of that board to make up our baseline of helps we have for the other boards.
I can't imagine it can be worse than a gigabyte 970 ud3p or an asus evo,at least it has to be equal as a newer model! Like said already, if they were all equal there would be no reason to ask an opinion on what is best. They are not all equal no matter when made. Period.
Anyway,i just oredered the asrock 970 fatal1ty performance.It's a 2014 model and i think it HAS to manage what it promises.I can't imagine it can be worse than a gigabyte 970 ud3p or an asus evo,at least it has to be equal as a newer model!
I don't know how you found it. It all looked Greek to me.
RGone...
Thanx for the wishes!I hope it's gonna be a solid motherboard.As soon as i get it i'll write back.I respect every word you say,since you know so much on computers and especially in o/c,just i picked the asrock cause i want to try something different and new.So,let's see what happens!
