So I know right around 0 about overclocking a cpu, all I know is that I want my games running better and to do that I need to overclock this thing. Let me know what you need to see spec wise/screenshot wise, here are current system specs:
OS: Windows 7 Home Premium
CPU: AMD Phenom II X6 1055T
RAM: 8 GB Dual-Channel DDR3 @ 669MHz
Motherboard: Gigabyte Technology Co., Ltd. GA-870A-UD3
GPU: Nvidia GeForce GTX 660 Ti
Power Supply: 700W
I'd like to get my cpu up around maybe 3.5, I'd like to go as high as possible but I need this to be simple because I have zero experience in it. I assume you guys would recommend overclocking with bios, if there's a simpler way that is similar with a program I can just grab that would be best, but whatever works. Right at this second, with War Z running in the background and spotify, as well as chrome up it's running at 35-36 degrees Celsius according to speccy. I do have water cooling, not sure about the specifics.
Here's some potentially useful pics, not sure:
Power Supply: 700W
