- Dec 14, 2010
I'd been wanting to check out an AM3 Sempron for a while. Off and on I would look into getting a Sempron 140 or 145 (150 is harder to find), but never really seemed to find one in the price range I was looking in, or they would sell before I could buy or make an offer.
I've finally found one though, so it's time to see what one of these can do (this one in particular at least).
It's been a while since I've run a Sempron, my last one was a socket 754 Sempron 3000+ 1.8GHz.
I think I'll just start off by saying that at stock speed and voltage this thing runs really, really cool. With a Thermalright Ultra 120 Extreme on it with Cooler Master SickleFlow fans in push-pull it idles at 27-29°C with or without Cool 'N Quiet enabled (doesn't seem to matter with a TDP this low), and under load with Prime95 it is 29-33°C. So, really almost no temperature increase at all when under load. Ambient temp in the room is 70-80°F/21-27°C.
I thought I would start by trying to find the lowest stable voltage. So, I lowered the vCore from the stock 1.35V to 1.25V, and I ran Prime95 for 5 hours with no errors and no warnings. Then, I lowered it to 1.2V and ran Prime95 for another 5 hours still with no errors or warnings. I set it to run a couple hours before I went to sleep for the night, then when I woke up in the middle of the night to get something to drink I saw it was still running the test, so I shut it down, went into the BIOS and lowered the voltage and then started another test.
Then, this morning I lowered the voltage again, this time to 1.15V (though it actually shows 1.14V in CPUID Hardware Monitor and 1.136V in CPU-Z). It's been running the blend test for 3.5 hours now, and still shows no errors and no warnings.
Thus far I'm impressed, and I haven't even gotten to the overclocking stage yet. It seems this CPU is very tolerant of under-volting and can remain stable well below the rated stock voltage/VID. There is no noticeable reduction in idle or load temperatures, since they were so low already, but there probably is some reduction in power usage.
It's not a bad little CPU for being a Single Core, I was doing program uninstalls while it was running Prime95 blend last night and it didn't even skip a beat.
Socket AM3 Sempron 145 overclock settings
2.8GHz (stock): 1.09V (1.1V)
2.9GHz: 1.09V (1.1V)?-Didn't test this frequency, just guessing.
3GHz: 1.12V (1.125V)
3.1GHz: 1.17V (1.175V)
3.2GHz: 1.17V (1.175V) or 1.18-1.20V (1.20V) (not sure if lower is/was stable)
3.3GHz: 1.18-1.20V (1.20V)
3.4GHz: 1.22-1.23V (1.225V)
3.5GHz: 1.25V (1.25V)
3.6GHz: 1.26V (1.275V)
3.7GHz: 1.30V (1.3V)
3.8GHz: 1.34V (1.35V)
3.9GHz: 1.36-1.38V (1.375V)
4GHz: 1.39V (1.4V)
4.1GHz: 1.47V (1.475V)
4.2GHz: 1.5-1.52V (1.525V)*Still testing
4.3GHz: 1.57-1.58V (1.575V)
4GHz: 1.39V (1.4V)
