First of all.. :
Sorry if I posted another thread but I'm really impatient, for the past couple of days I've been trying to overclock my i7 950 with no experience what so ever, I try to fallow guides but after prime95 test they are always unstable (crashed/bsod in 4 minutes). I don't know what settings to put.
I was planning on putting cpu ratio to 21x then increasing bclk 10 each time and restarting windows and when it is unstable increase cpu voltage, but heres the problem the two guides you guys recommended me adjust two different voltages, I don't know which to adjust.
This is what I fallowed (Clunk guide)
Ai Overclock Tuner - Manual
CPU Ratio Setting - Auto (If you are NOT using a 920, please set this manually to 21)
Intel (R) SpeedStep (TM) Tech - Enabled
Intel (R) Turbo Mode Tech - Enabled
BCLK Frequency - 160
PCIE Fequency - 100
DRAM Frequency - DDR3 - 1282MHz
DRAM CAS# Latency - 8 DRAM Clock
DRAM RAS# to CAS# Delay - 8 DRAM Clock
DRAM RAS# PRE Time - 8 DRAM Clock
DRAM RAS# ACT Time - 24 DRAM Clock
CPU Voltage 1.10000v
CPU PLL Voltage - Auto
QPI/DRAM Voltage - Auto
IOH Voltage - Auto
IOH PCIE Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
DRAM Bus Voltage - 1.66v
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
DRAM DATA REF Voltage on CHC - Auto
DRAM CTRL REF Voltage on CHC - Auto
Load-Line Calibration - Enabled**
CPU Differential Amplitude - Auto
CPU Clock Skew - Auto
CPU Spread Spectrum - Auto
IOH Clock Skew - Auto
PCIE Spread Spectrum - Auto
I used all these settings but it still can't run stable at 3.36.
My temps on idle is 29 C, 47 C full load on stock clock. Anyone willing to help?
System Specs
Asus Sabertooth x58 Mobo
Intel i7 950
Corsair XMS3 8db ddr3 1600 (1.65 volts, 4x2 gb sticks)
Corsair 750 watt psu
Nvidia 866 GT (waiting for new gpu)
Antec 900 case
Cooler master 212+ heatsink
Western Digital Caviar Black Sata 3, 7200 rpm 64mb cache
Creative Fatal1ty Champion Series sound card
PCIE Fequency - 100
IOH Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
System Specs
Intel i7 950
Antec 900 case
