You're temps are way too high under load. 55c is the max you want to be looking for when running prime 95, as stability problems usually occur once temps get around that golden figure.
Edit : are you sure you're cooler is seated correctly as those temps are poor
Lets see everything was the same bar the case and the h60.
what cooling did you have before the crappy h60 ?
Looks like your h60 is either incorrectly mounted ie tension from screws, Or the mating faces of the block and the cpu heatspreader aren't level, and or the thermal compound hasn't been applied properly.
1.4 v core on a typical air cooler like my titan fenrir or a Vendetta should get you core temps of around 40-44 at max load.
So if you have your previous cooler how about refitting it to test it out. Or if standard get a half decent air cooler.?
Maybe im drawing more power than I thought from this piddly *** Diblotek I have considering I have 2 200mm fans, 2 120mm fans, 1 80mm fan, 2 hdd,and that GC. Idk...
I had a stock cooler, the one that came with the AMD Phenom X6 1090t be.
As for the H60 you call crappy, it's not.
I've heard nothing but success from people using this model.
It's a hell of a better cooler than stock.
I can't just go out and buy another cooler right now either, i just bought this one around 3 weeks ago.
I thought water cooling was the way to go?
Did you not read my other comments?
