- Sep 16, 2008
@all,
I just registered to this forums and I hope to find some assistance here. I am relatively new into Quad-core processors and into overclocking in general and I didn't do anything on my own, but I can't proceed for any reason. First of all, my setup :
Asus P5Q-Pro Motherboard
Q9550 processor C1 VID 1,2375
4GB OCZ CL4 Reaper
Corsair PSU HX520
CPU cooler Noctua U12P
Case Coolermaster CM690 with 3 included 120mm fans
Graphics card ATI HD 2600 XT
Vista64
The BIOS modifications I've made so far :
CPU-ratio 8.5
FSB 400 MHZ
DDR2-800 (1:1)
CPU-Voltage 1,2125
CPU GTL Ref. [Auto]
CPU PLL Volt. 1,52
FSB Termination Voltage [Auto]
DRAM-Voltage 2,10
NB Voltage 1,28
SB Voltage [Auto]
Load Line Calibration [Disabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
C1E [Disabled]
With these settings, my computer is stable running Prime95 small and large tests for a couple of hours each without any errors or warnings. Temps after 4 hours of Prime are about 51°,51°,49°,49°.
A friend of mine told me that FSB Term. at Auto gives too much voltage. BIOS (I don't know which revision actually) tells me that standard for FSB Termination Voltage is 1,10, but whatever I do, I just am allowed to start at 1,20. If I try i.e. NB Voltage 1,28 together with FSB Term 1,2, my computer starts normally and I can work, but it won't restart and when switched off, it won't start. The only thing I can do then is to switch off the PSU and to enter all things in BIOS again. If I go to FSB Term 1,22, it's the same thing. I am wondering why I can't go below 1,20 in the first and of course why I can't restart my computer with some settings. Auto fits perfectly, but I am concerned it might give too much voltage. I don't want to keep the processor and the board for more then 3 years I guess, but I don't want to throw it away in 10 months.
For the usage, I am into multi-threaded video encoding which gives always 100% load to all cores.
Can you guys please assist me with some ideas, some opinions and some tips about my BIOS mods, what to do better, what to try ?
Thanks in advance for a thousand times.
Andy.
4GB OCZ CL4 Reaper
Corsair PSU HX520
Vista64
CPU-ratio 8.5
FSB 400 MHZ
DDR2-800 (1:1)
CPU-Voltage 1,2125
CPU GTL Ref. [Auto]
CPU PLL Volt. 1,52
DRAM-Voltage 2,10
NB Voltage 1,28
SB Voltage [Auto]
C1E [Disabled]
Andy.
