your ram 1333 at rated with 9 CAS at 1.5 V.
what you can do, if you want them faster, is first, set voltage at 1.65V, which most would agree is pretty safe for VDIMM, then by trail and error, you can test to see which yields you the best result.
you can start with 1600Mhz as Hokie mentioned.
if you cannot get them to boot, then loosen the timings to 10 CAS, I will guess you will have a Strong chance of getting them to work there at 9 CAS though
Now, the question of:
Also I hear 1333 @ 8-8-8-24 is better than 1600 @ 9-9-9-24.
the answer is that it depends, but yes, loosening the timings for such small clock change might not be worth it. If you want to find out which is better, try running Super-Pi 32M, and compare the time for it to complete. Obviously, faster is better.
Super-Pi 32M will also help you test the stability too, which is crucial, in mem overclocking.
