- Jul 5, 2003
- Deep in the Heart of Texas
hitechjb1,
You seem to understand advanced engineering concepts, do you know if anyone has done a DOE (design of experiments) to map out the best operationg space for a given set of overclocking parameters?
Based on your comments:
I'd think one could set up factors for Vcore, temp, frequency, %CPU usage, , etc, and measure the parameters used to monitor stability (time to fail, type of failure, etc.). Since overclocking is a combination of many factors, many of them interacting, then the best operation space could only be found by measuring the cross terms of the equations and not by setting OC parameters one at a time as is usually done. What do you think?
For those of you not familer with DOE methodology, here's a link to an example.
http://www.6sigma.us/DOEUnit1ReadOnly/doeunit11.html
><>Mr. Fri
Each CPU has its own stable operation region (a multi-dimensional region). Vcore and temperature are one of the many variables. Highest possible voltage and lowest possible temperature give the upper bound (or best case scenario) of a CPU to sustain its max frequency which is determined by the total time delay between one of the slowest pair of latches in a CPU (critical latch timing). This shortest time determines the CPU cycle time (Tmin), and its inverse gives highest CPU overclocking frequency (fmax = 1/Tmin). The higher Vcore gives more drain current (Idsat) driving ability for a transistor to drive a given load (Cload), the time is given by
><>Mr. Fri
