Hi all, dear lord it's been a while since I used a forum! I've searched high and low and tried various things (except start my own thread). Hopefully we can all get my rig up and running properly again before this lan party I've organised in 2 weeks.
My Specs:
i7 4770k (default clock)
Cooler: ANTEC h2o 650
Mobo: MSI Z87-G55
Ram: Kingston - Predator Series 16GB (2 x 8GB) DDR3-2133
GFX: Gigabyte- windforce gtx 770 4gb
OS: Win 10
So basically this is the turn of events that has lead me here. As far as what I've tried the order may be a little skewed but you can see what I've tried at least.
Previous OS was Win 7. Everything was working fine and I hadn't noticed any issues for a while. A friend invited me to the closed Sea of Thieves beta (he's a dev) but to participate I needed to install xbox insider and thus upgrade to win10.
I downloaded the free upgrade and proceeded to install.
Seemed to update without issue. All my files and programs carried across. I noticed the cfan speeds were really high and the indicator light was red. Checking the monitoring software confirmed that the temps were high. Task manager however says CPU utilisation is low which is wierd.
- I've re-applied thermal paste and got all the dust out
-I've optimised windows and disabled a lot of crap so my CPU idles at around 8%
-I've done a clean nstall of Windows 10 (which hasn't helped.)
-I've updated all my drivers
_I've run a 6 hour stress test which showed no errors.
Other useful bits of info, Since the isue started I haven't had any auto shut downs due to high temps, the CPU feels warm to the touch but not 100 degress tha the bios is reading. when turned on even when you boot into bios the temp and fan steadily creep up to max. Everything used to work ok but no I've started to get really low frame rates in PUBG.
Anything else you need to know please ask.
My Specs:
Mobo: MSI Z87-G55
OS: Win 10
