I have an P3 running at 650 mhz/ 100 fsb. My motherboard is an asus cubX motherboard with the latest 1008 Beta 4 bios revision. My fsb cannot be changed from bios, which is not a problem. I have to set it to jumperfree mode and set my jumpers. The max amount I can go up to is 150 fsb. Before i do anything the problem appears to be with my motherboard. I really dont know if my motherboard is able to support temp sensors because in bios the temp's are 0 F and with software like mm5 it cannot detect my temperature....
Is their a way to measure temperature..like a cheap alternative anywhere within Canada preferably not buying offline but at a store? Can people with the same motherboard also reply.
Thank-You for your support.
