- Oct 24, 2003
Juic3 said:Yeah, makes sense to reseat, any pointers ? I did the arctic silver website instructions just like it says right there. I would have to remove the AS5 or not ? Ive read AS5 is kinda messy to take off.
Ill try turning the fans around too .
yes you will have to remove the as5, its not hard at all, just use some alc, it comes right off, then wipe with some kleenex or something
Id recommend using a bit more as5 then it says on the site, as cpus with an ihs tend to have higher corners
D
