- Oct 24, 2003
Juic3 said:I see, ok Ill try an intake fan right there, that would make it 3 intake fans and 1 exhaust, or I just may try removing the 80mm thats in the front and putting it in the side, but that fans moving the air that the zalman is blowing hmmmm.
Oh I guess Ill be getting OCZ gold series PC3200 or KIngston HyperX 3200(any thoughts on this one please ? 119.99 at outpost.com), see how far I can go with low timings, will I gain much going from 3 4 4 8 to whatever I can get with the ocz, Im guessin 2.5 tops.
Guys, I really appreciate all the helpful info, thanx a bunch, youre all going to overclockers HEAVEN!
play with the config, change a few in and out see what happens, took me quite a few combinations before I found the best config for my system
don't know the kingstons sorry, got a link ? I can try to figure them out
the ocz should give you 2225 at ~200mhz (5:4) with 2.8v and just like Batboy said there is nothing wrong with running a divider, see my sig I'm also running 5:4
3-4-4-8 to 2225 at same speed is usually a big step and it shows, but mostly in benches
you are very welcome and thank you
D
