Hello people!
I did what I thought would be a very nice upgrade to my pc with these parts:
2x corsair vengeance 8gb
mb p8z77-m
i7 3770k
cooler hyper 212 evo
I put those together with the old ones:
gpu ati 5770
PSU corsair 650w.
(Before that, I had a p5kpl-1600 + quadcore q8200 + 4gb ram generic)
I put it all together, without touching anything but the parts itself while I was installing them.
When I first turn the pc on, parts worked, fan spinning, but I heard a beep noise, pause, then 5 bore beeps. Then the screen showed CPU FAN ERROR. Turned it all off, connected only 1 fanf rom the hyper to the mobo and tried again.
This time the standby green light kept flashing and the pc wouldnt turn on. Tried to change the jumper position, as the manual said, remove the battery as well, but nothing. Pulled out some parts and pushed them in again, tried to connect both 4 pins ATX from the PSU instead of only one, as the mobo is ATX 8 pins. Nothing again.
Got pissed, waited a while, did some more of that remove-plug back stuff and it turned back on. I hear the same beep sequence. And that's whats been happening ever since. Alternating between standby flashing and no power at all to beep sequence when I power it on.
Smart fellas, whats going on? Please dont tell me the mobo is faulty!
Maybe it's some configuration I forgot?
Or my PSU wont handle this mobo?
Or this mobo needs a 8 pin ATX from the PSU, instead the 2x 4pins I have now?
Or RAM incompatibility? (I didnt see the 8gb corsair in the manual list)
Or even CPU or cooler issue?
Or BIOS needs to be updated?
I tried to assemble on my own this machine cause so far everything had worked. Really, I have no idea what to do when these hardware failures occur!
ANY help is very welcome!
mb p8z77-m
i7 3770k
gpu ati 5770
PSU corsair 650w.
