Are these good or not?
Or what would you recommend? (needs to be the lower profile to fit under my cooler)
there will be review on OCF soon ... wait couple of days
here is preview
if you can't wait then here are 2 kits that have almost the same timings and should be on the same IC ( I'm not 100% sure but looks like all are Hynix ):
Corsair Vengeance LP 2133 11-11-11 1.50V
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233327
Looks like those are Samsung, at least the kit Newegg chose to take a picture of Ver4.1x = Samsung 2Gbit IC.
You can try Geil Veloce 2133 C10 ( about the same as Corsa 2133 CL10 ), review should be published in this week on OCF , some tests here http://www.overclockers.com/forums/showthread.php?t=712947
It actually made 2600 CL11-13-12-34 1N 1.65V stable on my rig.
Both Corsa and Veloce have tall HS. Low profile series are only Geil Leggera but I can't see them available yet.
As I said best sticks for AMD from LP series are now Crucial Ballistix http://www.overclockers.co.uk/showproduct.php?prodid=MY-143-CR
Maybe won't make much above 2000 but can make 1600-1866 on tightest available timings on market ( and low voltage ). Also available with blue/orange and green/red LEDs ... I have almost the same RAM in my brother's rig - Crucial Elite 1600 @ 1866 8-8-8-24 1.55V and I also checked that 4 sticks are running at the same settings ( friend got 2 of them ).
So what about these? http://www.overclockers.co.uk/showproduct.php?prodid=MY-121-GL :
Whats wrong with a little irradiated yellow on the spreaders?
