I just did an overclock on my i5-6600k with the asus MAXIMUS VIII HERO board. Ever since I did the overclock my computer wont enter sleep mode. The monitor shuts down and sleeps but the tower won't do it. I can manually enter sleep mode but it won't do it automatically. I started with everything on the default settings in the bios and only changed a few things (see below) is it possible something I changed when overclocking is causing this problem? I tried running command prompt and searching powercfg -requests and nothing comes up. I went into the advanced power setting and under multimedia setting I set it to allow the computer to sleep. I have no clue how to fix this issue and its driving me crazy!!!! Any one have ideas?
Below are the few things I changed in my Bios:
AI Overclock Tuner: XMP
ASUS MultiCore Enhancement: Disabled
CPU Core Ratio: Sync All Cores
1-Core Ratio Limit: 46
CPU Load0Line Calibration: Level 6
VRM Spread Spectrum: Disabled
Intel SpeedStep: Enabled
CPU Core/Cache Cureent Limit Max: 255
Min. CPU Cache Ratio: 8
Max. CPU Cache Ratio: 41
CPU Core/Cache Voltage: Manual Mode
CPU Core Voltage Override: 1.310
CPU VCCIO Voltage: 1.10000
CPU System Agent Voltage: 1.10000
