- Dec 14, 2010
I'm running into this odd problem with PCMark 04 and 05.
For some reason every time I run PCM 04 the benchmark seems to fail the Grammar Check test and/or crash back to the desktop when it gets to it and then gives me an error message saying "System suite must be selected and run to obtain a PCMark score.", even though that is exactly what I have done.
I'm not sure what is causing this issue, because it used to work fine up until just recently.
The only changes I've made have been to upgrade my 939 benching rig from XP Home to XP Pro and upgrading my board to a better one (I did a fresh install of the OS when I upgraded the motherboard).
PCMark 05 has similar issues, and seems to be failing to run (or give results for) about half of the tests in the suite (reason unknown) and is throwing out really low scores.
I've tried reinstalling both programs from the original installation files, re-downloading the installation files from the same website as I had originally downloaded them from and then a different site in case the install file I was using was corrupted somehow, and fully reinstalling the OS and then installing the programs.
Nothing has worked to fix my issues though.
Anyone have any ideas or suggestions?
