- Dec 14, 2010
- Thread Starter
- #21
I'm running out of possible causes to this... I've never played with such old chips so I couldn't tell you if that has anything to do with it.
I guess one more thing to try would be a HDD swap.
Well, just eliminated that possibility.
I just tried a different HDD with a different OS installation (XP Home instead of XP Professional) here.
I really think it doesn't like running on this dual core. Because there are two cores instead of one it can't make heads or tails of it and can't decide which core to run the test(s) on, so it is probably jumping back and forth between the cores, or it starts running on one core but ultimately errors out when it realizes there are two of them. I only think this because it ran fine with several of my single core CPU's.
I think next I'll swap out the CPU for a single core one, and then if that doesn't work it's probably the board (which I highly doubt because I've had this same issue with two different motherboards now) and I'm screwed if that's the problem.
I may ultimately end up having to buy a copy of PCMark 05 so that I can run the tests individually to see if I can get the tests that are failing to run by themselves. I'd rather not have to resort to that, but at this point it's looking like it may be the only solution.
