- Dec 27, 2008
Enable CPU LLC. Don't enable CPUNB LLC but try setting the CPUNB voltage to 1.225. LLC will supplement the voltage under load so keep an eye on max voltage and max temps. You may want to lower the baseline voltage if the LLC supplement increases the overall voltage under load to levels or temp that you are uncomfortable with. Don't be afraid of max voltages under load that go even as high as 1.55-1.6 under load if cooling keeps safe temps but you don't want 24/7 voltage that high.
