Push out is a pretty normal thing no matter the way the paste is applied.
I've always used a spread method. I start with a line down the middle and spread from there to the edges.
This method leave a small mound in the middle which helps ensure air doesn't get trapped. I do the same with naked chips.
But with testing leaving the line, a dot, an X ect, as long as there is enough paste you "should" have some push out.
When you see push out, that's actually good indicating paste has spread thoroughly across the IHS plate.
If lapping IHS plate and cooler surfaces, you should be able to use slightly less thermal interface material and have much better mating surfaces.
