- Nov 1, 2001
- New Iberia, LA
So far, all the modding I've done on my Tbred and Barton procs I've done with the L3 bridges, with the old style OGPA package. Now that they've changed up to the newer package, I'm thinking of doing my multi changing by the pinmod method, if I can have a few questions answered. I will be buying at least 2 procs soon to replace the aging xp2000 pally's in my A7M266-D and may also be replacing the 2 Tbred A 1700's in my K7D.
1. Can you just connect the holes in the mobo socket like they show at ocinside.de without messing with the L3 bridges? If so, how does it bypass the hard coding of the L3 bridges on the ones that are connected? For an example: The Barton 2500 has all 5 L3 bridges connected, so how does doing the pinmod for a 16 or 17 multi unconnect the connected L3 bridges.
2. Is there a pinmod to connect the last L5 bridge to enable SMP?. I know that it's not important and that you can just clean out the laser pit on that bridge and fill with conductive ink, but I'm just curious.
3. Which pins need to be connected to change the default fsb from 166 back to 133? ocinside.de doesn't show this on their guide as far as I remember. Again, it's not a must have, but it would be a nice bit of info to know.
4. Has anyone tried a mobile XP2400 on a SMP board or a single proc board and gotten it to work? I'm seriously considering using them because they are Barton procs with a native 266 fsb and a low (1.45v vcore) default vcore voltage.
Thanks in advance for answers to my questions.
