- Jul 7, 2013
- Thread Starter
- #21
I'm not sure what's going on here, I'm assuming this is an issue with me trying to use this from Windows 10. Here's the error I'm getting:
[/SPOILER]************** Exception Text **************
System.IO.IOException: The parameter is incorrect.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.Directory.InternalGetFileDirectoryNames(String path, String userPathOriginal, String searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption searchOption)
at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
at System.IO.Directory.GetFiles(String path, String searchPattern)
at .. ()
at ..(Int32 )
at ..(Boolean )
at ..(Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.8933 (WinRelRS4.050727-8900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
vlite
Assembly Version: 1.2.0.2
Win32 Version: 1.2.0.2
CodeBase: file:///C:/Program%20Files%20(x86)/vLite/vLite.exe
System
Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
vLite
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
MCDBNET2
Assembly Version: 1.3.3.33894
Win32 Version: 1.33.0.133
CodeBase: file:///C:/Program%20Files%20(x86)/vLite/MCDBNET2.DLL
msvcm80
Assembly Version: 8.0.50727.9445
Win32 Version: 8.00.50727.9445
CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.9445_none_d08c58b4442ba54f/msvcm80.dll
vhelper
Assembly Version: 1.0.3166.20582
Win32 Version: 1, 0, 0, 1
CodeBase: file:///C:/Program%20Files%20(x86)/vLite/vhelper.DLL
msvcm90
Assembly Version: 9.0.30729.1
Win32 Version: 9.00.30729.1
CodeBase: file:///C:/Program%20Files%20(x86)/vLite/msvcm90.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.[/SPOILER]
Not sure if you can make heads or tails of that, C, but if anyone else can, please feel free to let me know.
at .. ()
at ..(Int32 )
at ..(Boolean )
mscorlib
vlite
System
vLite
System.Drawing
MCDBNET2
msvcm80
vhelper
msvcm90
System.Xml
enabled.
For example:
<configuration>
</configuration>
