OK, so I've lurked long enough. I have to weigh in on this.
The test:
I took a standard US quarter, held it with tweezers, and held it over the flame of a bic lighter on it's lowest setting for 5 seconds. The temperature was measured by an infrared thermometer before and after. After the burn, both sides of the quarter were measured and the average of the two sides was taken. The temperature rose 15F which I convert to 8.3C.
The math:
One US Quarter = 5.67 grams total
Ratio of Copper to Nickel
.9167 Cu
.0833 Ni
Individual masses
5.1977 grams Cu
0.4723 grams Ni
Specific heats of each metal.
.39 J/g K Cu
.54 J/g K Ni
Specific heats time mass
2.027 J/K Cu
.2550 J/K Ni
2.282 J/K Total
Specific heats times mass and temperature rise
18.94 J
Divide heat by time of burn
18.94J / 5 seconds = 3.788 Watts
Conclusion:
It may be a lot of energy but if you want to heat up a heatsink, your processor will do it better than a lighter... ...unless I shouldn't be doing midnight math. =p
