Hello everyone i am new to this whole forum and i wanted to know if anyone has the same problems i am having.. okay so heres the problem i recently bought a corsair h60 installed it just like the book says with the fan blowing threw the radiator into my case with a 120mm fan at the top and the same at the bottom i also have a 120 blow intaking in the front. heres the problem i tried to prime 95 and check my temps out to see what all the water cooling was about and my temps go from about 12c to around 30c then jump straight up to like 206c and know that probably isnt right but would really like to know if anyone would maybe know why is was doing that,
SYSTEM SPEC
CPU Fx 6300 3.5 with turbo boost turned off
4 gb stick kingston hyper x and 4 gb of corsair both 1600mhz
cooler master 500w psu
GPU is a gtx 560
please HELP
SYSTEM SPEC
GPU is a gtx 560
please HELP
