- Jan 12, 2013
- Pittsburgh, Pa
Hi guys,
I would like to overclock my i7 3770k. I have a ASRock z77 Extreme 6 motherboard. I am also using a Swiftech H220 AIO water cooling kit. I have never overclocked an Intel system before and do not have any experience at all with ASRock boards. Therefore, the first thing I did was start searching for a guide. I came across this guide for Intel and ASRock. There are a few things that have me confused a bit. If I read correctly it says to start off with a CPU multiplier of 33 and set the offset to +0.005v. Then, to set Turbo Boost to +0.004v. After that it says to run prime. If the test fails to raise the Turbo Boost Voltage, or raise CPU PPL voltage up to 1.89, or lower it as low as 1.709v. My question is does the CPU Offset voltage stay at +0.005v and all the voltage changes are done to the Turbo Boost voltage instead?
Another part of the guide talks about what to set CPU Load Line Calibration too. It says to use either level 3 or level 2. It said that it depends on what the voltage says in CPU-z and that you want the voltage in CPU-z to match the BIOS. Well, my problem is I don't know where to look in the BIOS for the current voltage. If I am using Offset mode I have no clue what the voltage is in the BIOS. Is there a place in the BIOS that will tell me what the current voltage is like it does for some memory and some other stuff? Also, from what I have noticed it seams that the voltage in CPU-z bounces around quite a bit so from the looks of it wouldn't it be tough to match the voltages? If there is anything that I should do differently than the guide says please let me know. I appreciate you guys taking the time to read this and helping me out.
Thanks again,
Rocky
Thanks again,
Rocky
