- Mar 3, 2005
- Central MA
I was wondering if you could post some info here for me. I'm running a 651 Cedar Mill (Thanks to Epox4life) on water and my load temps seem a little high. I had a 661 until it died about a month ago and my temps would really sky on load. My ambient temperature is around 22°c, idle temps were 25°c and load would hit 55°c with 1.4375v. This was my first chip with my water cooling setup so i figured the temps were normal but after the 661 died i was trying to figure out why and some people said my load temps were too high for H2O. Some also suggested an improper water block installation.
After the death of my 661 i popped in a 630 i had for a spare and the difference in temps from idle to load were about 11°c. I then bought a 930 slapped that one in and had pretty good temps with that also, i ran it for a month @4.2GHz 1.35v with my idle temps @25°c and load @36°c. Then i bought another Cedar Mill from the classifieds (651 3.4GHz) and i'm having very similar results as my 661! At stock my idle temps are 25°c and load goes as high as 45°c. I haven't tried too much with overclocking yet until i get these load temps down.
Anyone who owns or has owned a Cedar Mill could you post your cooling specs, clock speed, Vcore voltage, and idle~load temps i would appreciate it. I see some people in the water cooling section and the difference from idle to load is sometimes as little as 5°c, is this possible?? Thanks
EDIT: Here's where my 661 ended up. http://webpages.charter.net/dyl/DSC04887.JPG
