It DOES work on locked chips. And I can change them to whatever (up 24x or down to 4x) will be stable. Heck I have a Duron running at 22x100FSB that is multiplier locked.dumbfish said:but it never did work on a locked chip.unless im missing something here.i mean it worked as far as it thought it was a mobile but that didnt mean he successfully changed the multi with stability.
Maybe but I would need to rewrite the first message to have intructions on how to do the mod and I am not very good at it. Maybe someone can write the instrucations on how to do that.hrhrhrFOOT said:sticky?
Petr said:It is bit 0 of register 44h. Thanks!
Don't you want to be the second most famous in this unlocking effort (after me )? You have nForce 2, I know the bit that should enable FID_Change... just it doesn't work. Find solution and you will be king.
DFI told me that it was only VIA DFI boards taht can do that when I spoke to him some time ago. Well that would require a BIOS mod or does it need to be done in DOS and then soft reboot or boot record load win2k? Cuz the register stuff I did was in Win2k no SPs (I dont think it makes a difference).lemak said:DFI Tech already told me nForce2 Chipset have some bug supporting changging multiplier on Fly(After system boot)....
if u know the register to set... why dont u try set it before system boot?
bulk88 said:DFI told me that it was only VIA DFI boards taht can do that when I spoke to him some time ago. Well that would require a BIOS mod or does it need to be done in DOS and then soft reboot or boot record load win2k? Cuz the register stuff I did was in Win2k no SPs (I dont think it makes a difference).
emboss said:The problem is with the nForce chipsets not supporting the disconnected state that is required for a PowerNow transition. No amount of register-tweaking/bios-patching will fix that.
Just wondering, how do you know that? and how sure are you? and howcome if ever other last manufactuer included it, why didnt nvidia? What about the registers (nVidia: nForce 2 (reg. E7, bit 4 = FID_Change Detect; reg. 6F, bit 4 = Halt Disconnect) - But there is high change this won't work, good solution hasn't been found to this date.) from http://www.cpuheat.wz.cz/html/Tweaks.htm ).??emboss said:The problem is with the nForce chipsets not supporting the disconnected state that is required for a PowerNow transition. No amount of register-tweaking/bios-patching will fix that.
emboss said:I'm not 100% sure, but I've talked to a couple of (supposed, though it's hard to be sure) motherboard designers via email. They basically said that nVidia's official line to them was that PowerNow was not supported on the nForce 1 and 2 chipsets. One mentioned that the northbridge correctly handles the bus disconnect but then does not respond when the CPU tries to reconnect (so the computer halts).
I suppose there possibly could be a way to make the northbridge work correctly, but if the motherboard manufacturers (who have full access to the nForce tech docs) can't figure it out, I'd say that it's unlikely that anyone outside of them (who don't have access to pretty much any of the low-level docs, either from AMD or nVidia) would be able to do it.
I can only speculate as to why it was not included, since nVidia doesn't really want to talk about it for some reason My main guess is that it's due to the nForce 1 and 2 chipsets being very much designed for high-performance. There's only so much design time available in a project (more or less ) and they possibly concentrated on performance and neglected to get the power saving features implemented correctly.
Oh, and lemak: the only known way to set the multiplier to anything but default on an Athlon is through the BP_FID pins. The northbridge has nothing to do with it{*}. This is how all motherboards that support multiplier changes do it. However, the BP_FID pins (along with the whole L1/L3 setup) no longer have any effect on the startup multiplier of the CPU. So you can try to modify the SIP stream (oh, and if you find any docs that actually provide any information on the SIP packets, I would be most interested ) but I don't think you'll have a lot of luck with it ...
{*} OK, the northbridge RECEIVES the multiplier as part of the SIP protocol, but I don't beleive it's sent by the northbridge at any point in time. Lacking the SIP docs, I can't be sure though.
bulk88 said:To Emboss:
I read in the Athlon datasheets about each processor having a JTAG interface, I read a little bit more and realized that thats a bios/flash chip/pin tester/SMbus/addresible registers wannabe interface. Is tehre any way to put in a new multiplier with this interface, or if its mb accesible or will u need to solder the cpu socket?
