this metric is only valid during a relatively stable near-full-load condition
I assume you're running a Ryzen? https://www.hwinfo.com/forum/thread...er-reporting-deviation-metric-in-hwinfo.6456/
The short answer, your motherboard is lying to the CPU about how much power it is using so that it will boost higher. Mind posting your specs? 67.9% is pretty dang low. I believe 90% is considered to be good, 80% around average. Also given that deviation, what is your PPT limit look like? It could be a case where the CPU just doesn't boost that high for other reasons. It's kind of like PBO but instead of raising the limits, the board is automatically tricking the CPU into raising them. There are still other features / safeguards / limits in place in the CPU.
Edit, important note
Thanks for that man. I'm a little chuffed that my CPU can overclock itself better then I can. Ill take a day off from it and come back. That pic was with core enhancement and PBO on, those values changed quite a bit depending on the load.
