- Jan 12, 2001
- Kansas, USA
Just got my new OEM 2.8 Prescott. It's running at default speed right now making sure it works ok. Here is the info printed on the chip (note that it's a 2003 week 50):
2.80GHZ/1M/800
SL79K Philippines
7350A620
I will confirm that it does run warmer than the Northwoods. I have it installed in my Swiftech watercooled case. I have modded cooling on the northbridge of this IC7 mobo. Case cooling consists of two 120mm intake fans and two 120mm exhaust/radiator fans.
Idle temps of the Prescott at default speed are very similar to both my 2.4C @ 3.4 gig and 2.8C @ 3.4 gig. Here are the load temps after 10 runs of Sandra CPU burn-in (which is really only moderately loading the CPU).
Prescott 2.8 load temps at default speed:
CPU=49.5, system=19, PWM=35.5
Northwood 2.8 @ 3.4 gig load temps:
CPU=43.5, system=19, PWM=32
Northwood 2.4 M0 @ 3.4 gig load temps:
CPU=40.5, system=19, PWM=30
Ok, time to O/C... be back in a couple minutes.
2.80GHZ/1M/800
SL79K Philippines
7350A620
