- Thread Starter
- #41
I really get a kick out of you Jack. Honestly. You go off on these long rants that are judgmental, argumentative, and borderline rude, and then try to tell people it isn't personal Who are you trying to kid? You seem to get wound up anytime someone disagrees with you. Relax, go have a whisky or something to calm yourself down.
Apparently this isn't ok with you.
Look, I'm not interestd in what someone else did. If someone else thinks the Classy Hydro Copper cards and those Swiftech fittings are the greatest thing since sliced bread then I am happy for them. They are welcome to their opinion. However, it is my opinion that those Swiftech fittings are junk, and from what I have seen they are the only fittings that can be used with the 780 Classy HC in a SLI configuration with single-slot spacing. I don't like the fittings and that is based on actual expereince with them. And since there was no other option available to connect my cards I decided to replace the Hydro Copper blocks with parts that were designed to work together. I'm not happy about spending more money, but I am just fine with the decision. I haven't a clue why you would take issue with it, but that's your problem and not mine.
And so it remains my opinion that one is better off with a reference design board since it opens up more GPU block/SLI fitting options. I'm sure you disagree with that too...but I'm fairly certain that I'll get over it.
...since it is my money being spent here I will be the judge of what is and isn't best for me. Hopefully that's ok.
