A neighbour asked me to see if I could find the problem with his new mobo. From the things he described I expected either 1) bad cooling, 2) inadequate PSU or 3) OS issues. But I'm not sure it's any of the three. The problem is the system locks shortly after loading windows. It locked once when I was there and it was in BIOS at the time. The setup has a foxconn M61PMV for mobo, X2 5200+ cpu. I checked the stats in BIOS. The voltages are all steady even though the PSU is some name I never heard of (Thame Star 450w, 20A on the 12v) so I'm not sure it's a weak PSU issue. The video card is only an 8400gs so it's not like that's going to put a big drain on the PSU and even if it did, why would it lock in BIOS? My limited testing is only the BIOS readings of voltages, nothing from windows itself, but the 5v line is solid at 5.02v and the 12v line is at 12.03v I doubt they'd be dropping that much when idling at the desktop. The temps don't seem bad either but then I don't have experience with AM2 so I'm not sure. It starts in BIOS at low 30's and then slowly, over about 5 minutes, climbs to 38c where it stays. Is that about right to idle for that chip? So it doesn't seem to be either temp or voltage related from my limited contact with the system. Also the memory is set to "auto" so it shouldn't be an issue of timings too tight.The OS is XP with a fresh install so hopefully that's not it. So..... any thoughts?
