ok I just put a new system together with the intention getting into overclocking.....it is as follows
epox 8k5a2
1800+ Tbred
2 x 256m samsung 2700
msi gforce 4 ti 4600
80gig wd with 8m cache
antec true power 480watt
(cant remember the stepping on the chip but it started with az.....)
first of all i had a hell of a time installing win xp - ended up having to disable sse in the bios - a bit of time on different forums told me this is a common problem with winxp combined with that chip and mb
now i dont seem to be able to really overclock at all.......first i tried setting vcore to 1.525 (1.50 defult) and vdimm to 2.6 (2.5 defult) and bumping the fsb up to 140, no worries there so long as my memory settings are on fastest (turbo settings wont work at all even un-overclocked) next i tried lowering the multiplier right down to 9x and increasing the fsb to 166 but it wont post at all, i turn on the machine and get nothing but a blank screen and am forced to reset the bios via jumper, it dosn't seem to make any difference even if i bump the vdimm voltage up by another .1 or .2
now this is my first ever attampt at overclocking so am i doing something wrong? but even then i should be able to use turbo ram settings on an un-overclocked setup shouldn't i?
i suspect that i have a dodgey piece of equip somewhere as even when not overclocked (or only overclocked to 140) unreal t2003 seems to crash quite a bit and prime 95 gets errors after only minutes
i have flashed my mb with the latest bios, downloaded the latest via 4 in 1 drivers and all that
i only have stock cooling but my temps dont seem to go past 40
any help would be appreciated
- ben
epox 8k5a2
1800+ Tbred
- ben
