- May 28, 2005
- Tigard, Oregon
This project will basically be a combination of Blue I and Blue II (never finished). It will use most of the hardware from Blue I with some minor upgrades (while I save for completely new hardware) and my ubber custom modded Chenming case from Blue II.
System Specs:
CPU: AMD 64 3000+ Venice (maybe a cheap upgrade to a X2 CPU?) - Have
MOBO: ASUS A8N SLI-Deluxe - Have
RAM: OCZ Gold Edition 2GB (2x1GB) DDR500 (PC4000) - Have
GPU: eVGA 6600GT - Have
HDD: Western Digital Raptor WD740ADFD 74GB 10,000RPM - Need
PSU: PC Power & Cooling Silencer 750W - Need
Optical: Plexor PX-716SA/SW SATA (Black faceplate) - Have
Case: My insanely modded Chenming case powder coated gloss black - Have
Cooling System:
Intake Fans: 2x 120mm x 38mm Panaflo M1 with a gutted M1 120mm x 38mm fan as a spacer (inside of spacer lined with sound deadener) - Have
Rear Exhause Fans: 1x 92mm x 25mm Panaflo M1 with a gutted M1 92mm x 25mm fan as a spacer (inside of spacer lined with sound deadener) - Have
Top Exhaust Fans: 3x 120mm x 38mm Panaflo M1 with a gutted M1 120mm x 38mm fan as a spacer (inside of spacer lined with sound deadener) - Have
PSU Fan: My custom PSU fan contraption:
The outter fan is a Panaflo M1 and the middle is a gutted M1 (inside of spacer and 120mm to 80mm adapter lined with sound deadener) - Have
Fan Controller: Frozen CPU 3.5" 3-Port fan controller - Have
Im still deciding if I want to try water cooling again since the case I will be using was originally built for WCing.
Project Costs:
CPU Upgrade:
HDD Upgrade:
PSU Upgrade:
Case: I think it was around $60
Fans: Probably close to $100
Fan Controller: $20
Fan, PSU Silencers: Around $25
Sleeving: $20
Misc: $20
Total: Around $245 (so far)
It seems like it shouldnt cost that much, but I will be using this case in my next build and wont be touching it at all!
This project started out as a completely new build, but I decided to for the most part use what I have but get a quieter system and then get new hardware.
Thanks
System Specs:
Cooling System:
Project Costs:
CPU Upgrade:
HDD Upgrade:
PSU Upgrade:
Fan Controller: $20
Sleeving: $20
Misc: $20
Thanks
