Do you have a have another system or friend you can test that firepro in just in case?
Unfortunately this is the only tower that I have, but I can take it over to my parents place and test it in one of their systems. Its just a PITA lol.
In the back of my mind I am a bit worried that I somehow wrecked it when I had the heatsink off to measure it up for the custom waterblock even though I was extremely careful with it...
I hear ya but I believe that is your only option tbh so you can move on. It's possible while handling it static might have gotten in the way or you crushed the die? I trying to think every possibility here with the info you gave us.
nice
are you planning to use a MB with onboard graphics?
If not, but planning a discrete and assuming "standard" MB orientation... where are you going to put it? I dont see the slot... but maybe its just me, i'm just not seeing it?
I would buy that case.. (well maybe a few changes) but would be cool to see you take this to the next stage!
Taller, room for Monstas 80mm with push pull in the top, would be awesome!
Very nice project!
Build to suit with the frame as a starting point. Offer both VGA orientations! I would LOVE to have the fan side of my 270X visible...
