This is a good point.
The rear panel can be swapped out fairly easily so I could make panels designed for both VGA orientations.
This also applies to the top and bottom panels, they can be made any height to create more or less room for radiators and fans, changing these would require new side panels though, unless I design a 3 piece side panel where the middle section always stays the same and each radiator compartment has its own small side panels.
Now your'e going in the right direction In all honestly I think that looks better than the CaseLabs and MM tower cases. You really did a top notch job Snowman.
