Project "SKYNET" - please help to choose parts and safe-overclock an i7-based PC
Hello overclocker-experts!
first of, i appreciate your help. you are (part of) the people thanks to whome typing important technical question into google does yield results, and therefore thanks i know i ask very much, but i just need to know before dumping money on bad stuff or frying my CPU
I need some help finalizing my choice of components and then overclocking my new PC, once i got the parts.
After a while photoshopping HUGE-*** files and rendering raytraced images in 3D, i got fed up with my old core duo @1.86 ghz, 2 GB ram power-pc
Photoshop eats RAM like pie, also needs a good gfx card to quickly display huge images when zooming/panning while working
3D apps need a special gfx card which is expensive as hell and also sux for gaming; but its also happy with a good multicore CPU, which sounds like a good idea to me, since im not rendering ALL the time
its time to get myself a serious MONSTER straight from hell. and then overclock it.
main purpose is the aforementioned grafics work, but good gaming is an appreciated sidekick. after all, i can justify the PC costs by the fact im gonna use it for work ..WHILE NOT PLAYING GTA 4 ON FULL
i will mark the questions/insecurities orange, for a better overview
so far, i have come to think of these parts:
- Asus Rampage 3 Extreme
http://www.newegg.com/Product/Produ...131642&cm_re=rampage_3-_-13-131-642-_-Product
future-proof, isnt it? also supports 24 GB of ram, which i want, and supports the 980x CPU well... i am pretty secure about this one.
- i7-980x processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115223&cm_re=i7_980-_-19-115-223-_-Product
Corsair H50 closed CPU watercooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010&Tpk=h50 corsair
-> i want to set the cooler to exhaust the warm air from the case, unlike corsair suggests - they advise to let it pull fresh air into the case, but imo a bad idea; to help the process go my way, i want to mount an additional noctua fan on the radiator, so the radiator is sandwiched between two fans and can get more air
- G.Skill Ripjaws 24GB ram kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231359
--> I got the most difficulties with this one. there are 1333 and 1600 versions, the 1600 costing about 150 euro more, which isnt much, considering the overall cost of the rig. however, as ive heard/read, the 980x supports only 1066 RAM. now, i know the higher cloked RAM will just clock down and not burn or something.. but could someone explain me the whole RAM-CPU relation? im somewhat lost there. why cant the newest, most brutal processor support a higher clocked ram then just 1066? ? how do people use higher clocked RAM then?
also, the whole unlocked multiplier thing confuses me. with a regular cpu you just clock down the fast ram and then increase the FSB multiplier, untill the ram reaches its regular clock, or am i wrong there too?
if i overclock my extreme edition unlocked multiplier cpu to say 4.2 ghz, will it support a faster RAM timing then? do i need it to support 1600 instead of 1066- is there a real-world difference? and most important- how do i do that stuff with rampage-3 safe presets so it jsut automatically clocks or somethign like that? heard something about it being possible.
if i do overclock it, is a RAM-fan advisable, since there is not much space between the RAM-sticks, or does the good antec case do the job then?
- nvidia GTX 480 grafics card (for CUDA), Zotac AMP! edition (a more silent and efficient cooler then the reg leafblower edition)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500166&Tpk=zotac amp! 480
--> is CUDA really that good for what i need? or should i rather go with a card that has more memory? GTX480 cards all have 1500 afaik, maybe radeon with more memory is better?
Crucial Real SSD 128 GB as system drive; also gonna pull current projects temporarely onto it, so photoshop doesnt need 10 mins for every qucik save.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148348
any better SSD comming out any soon?
2x RAID-0 Momentus XT 500 GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148591&Tpk=momentus xt
-->afor total 1 TB of storage. this is where i got my music etc, but mostly where i dump my pictures to and where i work on them. not ALL my projects are huge, some are just regular. and i thought that an SSD-backed HDD RAID-0 will kick *** there - when working on not-so-huge projects (which i cba to copy to system temporarely), it would notice which files i open regularly, and speed up the photoshop open/save times for me, unlike if i had regular HDDs. accessing the rest of the archive will still be "slow", but accessing current projects will speed up thanks to momentus XT technology.am i right or wrong with this idea?
dont worry, i do have an external HDD for backup, so im not worried about RAID-0 death
- Antec 193 case
http://www.legitreviews.com/article/1261/1/
-with one additional intake fan on the front (by default it has no fan on the front)
--> do i maybe need two intake fans?
also, does the rampage 3 fit into a regular ATX case? it is 1 inch wider then a regualr ATX board. midi cases cost like half of the big towers : / I would consider IN WIN Android instead of Antec 193, if someone can tell me that it is a good idea. how does android perform compared to antec193 in noise dampening? what about cooling and collecting dust? any experience with either cases?
OVERCLOCKING
what about SAFE-overclocking the processor on this MoBo and with this cooler? I dont want to be badly messing with a 1k dolalr processor, but not overclocking the 980x is a sin. i heard on rampage 3 there are some presets in the BIOS for safe overclocks for 4.0 and 4.2 GHz.
and whats the entire deal with the RAM when overclocking?
in general, i dont care for benchmarks etc, but i want a stable, fast system, in which i do take the extra bit by overclocking it slightly
thanks in advance,
Jay
- i7-980x processor
- Antec 193 case
OVERCLOCKING
thanks in advance,
Jay
