- Apr 25, 2002
- San Antonio, TX
3- I was not too disappointed that the wires showed. After all, what is the use of sleeving with UV reactive sleeves and installing a total of 6x UV CCFLs if I'm going to hide it all?
Above everything else, the color is awesome! But I agree with the others who say you can manage the cables just a wee bit better. I understand you don't have a easy case, and that's fine (mine is not wire-friendly either) but just a little bit preparation and brainstorming will go a long way to the execution portion. You will be surprised at the result.
I spent time planning this out, and it all didn't go to plan, but as you can see I can't really go behind the motherboard tray like all the newer cases. Not to ***** my system, but to show you that it is doable if you put some work in, and that I am surprised you don't have UV zipties. THat would compliment it very well
Pic 1
Pic 2
Hope this helps!
