Captain Slug said:
I may be able to do the grill design too if you want.
I`m currently working on the grill but I will contact you via PM.
That design is also awesome Captain Slug and Frozen CPU are awaiting the design and measurements so they can begin.... payday is next week so I`m hoping it`s already to go by then... I will PM you later today with the exact length I require and also the other things we talked about in my last PM.
Thanks for all the input and advice everyone on the window and grill, I think we should take this to PM`s for now as we are moving away from the Picto Journal and it`s getting cluttered with stuff that isn`t ready yet.
Once I am ready to install and build the window it will be posted and credit given to those who contributed.
Sturm
Thanks for the work, but I decided to re-draw it by hand as it needed slight alterations, that can`t be noticed by the eye as this symbol is my family mark still used for marking important documents so it needs to be exact and hand drawn is probably the best way to go with it at first. But thanks again.
I will probably posting an update either today or tomorrow as I have finished another stage of the project and I will be installing it either tonight or tomorrow, probably posting how I did it tonight and then the Installation shots tomorrow, Then I will be working on the LCD to go in the last free bay slot.... I must say I`m very excited about it as I have been playing with the controller getting it to do some amazing things but more on that when it`s ready.
Also while going through my parts bin a came across some other things and I`m tempted to try out a few ground breaking ideas nothing major but good fun.
